Superchargers !!
https://forums.aussieveedubbers.com/threads/5310/superchargers
bugboymatt ·
Ok who has one fitted to there ride !!!!
Was contemplating the idea whilst out working today !!!
Any tips hints reccomendations stuff like that pics stories. Fores againsts.
What carbs / supetrcharger people using what size engines you running them on !!
Gees almost asking what ya had for dinner !!!
All that good stuff to help mess up my mind even more !!!!
:bounce
sand kombi ·
check the thread
http://www.aussieveedubbers.com/forum/viewthread.php?tid=4980 hope it helps:beer
HotRodMatt ·
Have U2U'd you.
Don't want to post too much on here about suppliers who aren't sponsors.
You will find the info useful.
blk56 ·
I have a Judson ready to bolt on but I dont know what the pros and cons will be yet:bounce
HotRodMatt ·
I've just finished writing an article on Judson and Shorrock super chargers... I'll put it up on the Flat Four website tommorow or wednesday night... will post link then...
kafer70 ·
Are Judson's as hard to obtain as i've heard ?. If not who can I talk to.
OvalGlen ·
blk56 , the judson would be good to blow a stock 1300cc.
Best value for money at present is the Toyota blower for anything bigger or wilder.
( a fully worked 1300 would need more than a judson)
penguin ·
Glenn,
I believe that you and I have got to talk 😀
Step child is getting worse every day :P
Penguin (See you on the weekend)
This will be intersting
Have you got one fitted ???
kombi_kid ·
im in the process of contemplating supercharging (previous post) a type 4 2L so any info u find out would be great!!!
cheer
rhys
Purple Martin ·
kombi_kid wrote:im in the process of contemplating supercharging (previous post) a type 4 2L so any info u find out would be great!!!
cheer
rhys
Me too! 😀
blk56 ·
The JUDSON will be being used on A 36hp motor .As for finding one they are not that hard to get from the US but be prepared to pay big dollars:bounce:bounce:bounce
bugboymatt ·
Looking at charging a 1914 !
So will have to read up before make leap.
kombi_kid ·
one thing that was argued in a previous topic on this was weather an intercooler is needed??? can any body give me an answer??
rhys
bugboymatt ·
HotRodMatt wrote:Have U2U'd you.
Thanks for that i will follow it up. Only managed to get into u2u when got back from nats. Saw the display !!!
You got your articlue finished ? interested to have a look at it ................
blownKombi ·
Kombi kid, in my experiances an intercooler is not necessary but it will gain more power. On my 4agze(blown corrolla motor) my intercooler made heaps of difference. Before i put extra scoops on the side the intercooler really did nothing but after the scoops it gets really cold now and i can feel the extra power
OvalGlen ·
I'm in process of supercharging a 1915cc
(could be the same as 1914 or 1916 )
the best value for money would have to be the Toyota blower off the 2L 6 cylinder.
It is 43 Cu in.
You could find out the drive ratio when used on the 2 L and run it less.
Mine is a 40 Cu in (USA built Magnacharger, if you are into VW Drags you would have seen two of them on a Rail a couple of years back)
I will run 1.25 : 1 thats 25 % overdriven,
Will have to see what boost it gives.
Tried to calculate but only running it will show.
I am aiming for 7Lbs boost ( secretly hoping it will give 8Lbs) which is a good healthy street state.
Water injection really helps with the heat build up,
I'm keen to get Greedy (Kombi) going properly and see if he will do comparison test for us.
Like Steve I intend to run a sidedraught, One day I'll connect my injection to it.
aussiebug ·
Last year at Adelaide's big Bug Day Out I spoke with a guy who had a stock 1600 with the Toyota supercharger and small Toyota twin throat carby, sitting in his "Shit box" 1970 bug (a real roughy).
This thing had an airconditioning type electric clutch on the pulley so he could turn it on of off on the move - when off it freewheeled and drove like a normal 1600.
He said that he could blow the doors of the older V8 Commodores when climbing the freeway through the Adelaide hills, but he couldn't work out why he kept blowing cylinder heads.
A quick look told the story. He had half the tinware missing. No underside plenum pieces, no under-head small flat plate deflectors (he did have the under-cylinder deflectors), and no rear tinware in the engine bay, so he was mixing used cooling air with the fresh stuff.
The poor thing was being cooked every time he turned on the supercharger.
The VW heads have only enough finning to shed about 45hp heat continously, so although it CAN produce more power, it's wise to do it for shortish periods and have a VERY tight cooling system.
There is no "reserve" in the cooling system like there is with a water cooled engine - you have to get rid of the heat as it's being produced, so a doghouse shroud is the starting point, and then perhaps a set of type3 "cool tins" which cup the undersides of the cylinders for better control of the cooling air there. These also have ears which cup the exhaust valve area for improved cooling and the design also improves head cooling, since they actually REDUCE (but use better) the cylinder airflow and this increases the pressure in the plenum above, so the heads get a better airflow. Carefully removiing any casting dags which partly block the head air passages can help too.
The flaps and thermo are very important too. The thermo provides a rapid and even warmup (even in warmer climates) and the cooling flaps, when open, provide a separate air path for the head and cylinders. Without the flaps the cylinders get overcooled and the heads get undercooled.
That's just the start of it of course - external oil coolers, water injection and so on might be needed too - depending on the application.
HotRodMatt ·
The article with the Judson stuff is up... won't tell most people what they don't know but an interesting read anyway...
http://www.flatfour.org/forum_files/vintagespeed.html#judson
Matt
OvalGlen ·
Yeah good Matt, did you research numerous sources.?
Must admit I did not know about Shorrock.
vanderaj ·
Might need some plumbing work
http://www.bahnbrenner.com/bbmservices/screwcompressor.html
Download the MPEG - it's awesome.
Andrew
kombi_kid ·
hey
talked to mike frtom CBB and he said he wouldnt run a supercahrger at all without injection (2 grand for it) and he is using a MX5 V6 supercharger he also said u dont need to run an intercooler cause through a carb it is hard (and of cause no water injection)
what superchargers are people using u all sound like ur running watercooled engines??? i wanna do a 2L type 4 motor
oh yer he also said he wouldnt use standard cast heads he said its a MUST to use forged pistons!(how much and where do i get these from?)
rhys
Whilst it is not a VW, my car is supercharged. EH Holden with Terra Charger.
OvalGlen ·
Peter is your EH running a single V belt , / Does it slip.?
Kombi Kid, if you only intend to keep at low boost ( like 5 Lbs ), you just get extra Torque ( plus a little extra heat) thus you wouldnt need anything fancy.
I didnt Know Mike and I disagree on so many aspects of supercharging.
I'd better hurry up and finish my manifold - see if he's right.🙂
The belt is a 6 groove like a Commodore.
A 'V' belt would slip with the 12 pounds+ boost I am running.
Rod Hadfield makes supercharger kits for Holden 6's using the Toyota pump, and he runs a V belt. I think they only run 6 or so pounds.
