Where do you get whiteline sway bars from?
https://forums.aussieveedubbers.com/threads/53130/where-do-you-get-whiteline-sway-bars-from
Fireball xl5 ·
Hello, just a quick question, where do you get whiteline swaybars form and how much are they?
Looking for type 3 ones to fit a 69.
www.whiteline.com.au I think
phil ·
vintage vee dub, burson auto, auto one..theywill prob. have to order it
Fireball xl5 ·
Thanks for the, looked at the wesite but just told me they did them, rather than price or anything really usefull! nearest autobarn place is miles away..
seagull ·
I have been using HR holden
humpty ·
I assume you mean for the rear of your TIII, Fireball xl5.... Right? The front has a swaybar built in and you cant buy HD ones for the front offf the shelf.... But they can be made... At a cost! I have a whiteline on the rear of my square and its very flat through the turns, but I feel it does hang down a little low... Its never touched anything, but it could be mounted a little closer to the torsion housing.... Even better would be to mount it above the transaxle with drop links.... I wonder if that would work???? Hmmmmm.
bus914 ·
www.whiteline.com.au/store/
keywords = vw
really? how does it work?
so you only need to buy a rear one?
humpty ·
bus914 wrote:www.whiteline.com.au/store/
keywords = vw
The top 'tube' runs an internal swaybar and the bottom 'tube' runs a torsion bar set (on bar per side)..... Thats why when you adjust the height of a TIII you only reposition one trailing arm per side.... The lower one.... And you can only buy a rear one and they only make them for IRS rearends.....
66deluxe ·
I got a front and rear for my type1 and they were $230.00 each.
humpty ·
66deluxe wrote:I got a front and rear for my type1 and they were $230.00 each.
Yeah, but we are talking about TIII's... The rear swaybar is the same for the TI and the TIII..... But I think seagull's HR Holden one makes a nice compact rear bar and its potentially cheaper too!.... He gave me one the other day to try out on my Ragtop.... Cheers for that Neil!
bus914 ·
page 98 of their cattle dog: http://www.whiteline.com.au/docs/catalogues/WL_031.pdf
BWF10 22mm and
BWF10z 22mm adjustable
front Whiteline swaybars for a TIII.
But i think you're right about the top tube. i looked into the manual and it does look like a sway bar.
Fireball xl5 ·
thats what confused me, ah well.
jakjones ·
they do make em 4 type 3 @ the front in Whiteline..
Special Air Service ·
Contact "dumone" from this website, I'm pretty sure he can get them for cheaper than retail.
Brendan
Or it might have been Craig Torrens who I was thinking about, shoot them both a U2U and see how you get on.
Cheers again
Brendan
humpty ·
Well there you go... They never use to make'em for TIII's, but I guess its a good thing they do... the stock one is pretty slim.... Kinda like the OEM bug ones... VERY thin!
