dizzy caps 010 wanted
https://forums.aussieveedubbers.com/threads/53242/dizzy-caps-010-wanted
ragtopp ·
I know its a big ask, but i need a couple of 010 dizzy caps. The ones ive got running on my car are cracked badly, they work for know but who nows how long. Hope someone can help
I thought they are the same as 009 dizzy caps as My Son has one on His engine.....
I know they aren't the large VW cap....
and the distributor is very similar to the 009.....
I've never seen 010 caps for sale.....
so I think the 009s use the same cap.....
as I don't think they retard no3 cylinder either....
I haven't been able to find out anything about the 010 dizzy on CIP1....
so I'm pretty sure thay are the same cap as 009s..
dangerous ·
Has a cut-out for the threaded piece that couples the points and condensor.
I think it is the same as an oval/36er cap, and should be in the Bosch cataloge.
Talk to Vintage, but any bosch parts seller should be able to get them in for you.
ragtopp ·
Thanks dangerous, thats right it has a little cut out for the rim to sit on the dizzy, and is like the old 36hp cap, different from all the other slightly.I will try vintage then.
68autobug thanks to mate, they are similar to the 009 but the cap is slightly different, they are fairly sort after for hi-po applications, not sure what difference is in the advanced curve to the 009 but they are mechanical advaned like them.
karmen ·
how many u want
similar to merc ones and early torana (bosch)
merc even has a dust cover unsder them
make an offer and will add post from 4650
