Aussieveedubbers 路 Tech Talk
cant get spark? spectron van
https://forums.aussieveedubbers.com/threads/5329/cant-get-spark-spectron-van
type82e 路
Ive been frigging around with this spectron van now for months and need help it was running when i got it but my wife cooked the head so I pulled it off and had it fixed when i ve had time but cant seem to get it running again
I cant get spark
it has power at the coil but none at the plug it has a gap in the points
so could it be coil or condenser?
and if so how do I test that?
marcel
kombikim 路
Hi Marcel, when you say it has power at the coil does this mean the coil lead sparks when you pull the lead from the cap & hold it about 4mm from earth & turn the motor? or just that it has current going to the small terminal - if you have spark from the coil then it is not points or condensor cause these initiate the spark at the coil, the diistibutor cap & rotor button distribute the spark to each plug
SOMETIMES people forget to put the rotor button back on -just asking- inspect it carefully & also make sure the small carbon rod is still in the cap from the coil lead terminal, it makes contact with the rotor button & sometimes falls out馃檪
type82e 路
Ive worked out the no spark delimma
the lead from the coil to distributor wasnt connected properly I got it runnig tonite finally!
marcel
