Che Castro wrote:I think the idle jet on dual carbs is inside what is called the "idle shutoff valve". It uses a solenoid to cut fuel to the idle jet when the ignition is switched off. The idle shutoff valve is easily identified, its about the size of an AA battery and has a wire running to the back of it from the coil
On the 30 series carburettors the idle jet has the cut-off solenoid screwed into the back of it and is on the right side of the carby. It's usually a 55.
On the larger 34PICT/3, the 31PICT and the Brosol H30/31, the shut-off solenoid is moved the the left side of the carby and the idle jet is then a plain brass "bolt" in the right side of the carby - it has a silver "plug" in the middle sealing the hole drilled into it.
It is still usually a 55 for most Solex carbs used on beetles (28, 30 and 34 sized carbs), but it a 65 for some KGs, and for the 1600 kombis (both having a heavier body than the beetles).
There is also a power jet in the right side of the 34PICT/3 and later carbies - it should be smaller than the idle jet and on mine it is a slotted "screw" rather than a "bolt". The power jet is usually a 65.
The VW engine runs on the idle jet from idle up to about 2500rpm, gradually handing over to the main jet from about 1500 upwards (it's really an airflow thing but rpms are easier to understand).
It gets all it's fuel via the main jet, and the result is that a larger idle jet provides a richer mixture at idle and slightly above idle, and the mixture than leans slightly as the main jet starts to take over.
