I have a set of brand new in the box never had tyres fitted 5 Lug Radars, Grey in colour.
They come with caps but no nuts.
$650 for the 4.
David
handycam ·
were thay on ebay ???
handycam ·
sent u2u
VWFOOL ·
also u2u sent
BUGBOY ·
These will not fit an oval or early beetle with small brake drums as the centre hits inside the rim before they fit flat on the drum surface.
You can how ever fit later 60's brake drums and problem solved. Correct me if i'm wrong.:thumb
[ Edited on 14-6-2006 by BUGBOY ]
Calcool ·
Hi Bugboy,
No Offence but have you fitted a set on and early Beetle?
These are the Air Evo Replica Radars.
I have a set fitted to my original thin drummed 58 Beetle which is the same as Oval.
They fit strait on.
David
vwtyp2 ·
BUGBOY wrote:These will not fit an oval or early beetle with small brake drums as the centre hits inside the rim before they fit flat on the drum surface.
I've got these rims on my '54 with original brakes.
bolted straight on.
[ Edited on 15-6-2006 by vwtyp2 ]
BUGBOY ·
Like i said correct me if i`m wrong, but i have the same wheels and they won`t go on my oval?:thumb
I might have to look into it a bit more, but the centre dust caps hit before the rim was against the drum?
maybe i need to change dust caps?
[ Edited on 15-6-2006 by BUGBOY ]
Calcool ·
Hi Bugboy,
No Worries, looks like you got a bumsteer, are yours the Air Evo?
So they are hitting on the cone!
Bugger,
David
vwtyp2 ·
mine came from Roy.
cost more than $650 too.
BUGBOY ·
same wheels, i`ll have to try again,i could have had a few to many beers?:P
BUGBOY wrote:i could have had a few to many beers?:P
hmmm...... wheel round the wrong way?? 🤓
BUGBOY ·
perhaps it was around the wrong way?:thumb
proctor ·
how wide are they? would they fit a 69 kombi? pics?
Calcool ·
Hi Proctor,
They are 5 inch wide.
I am not sure how they would mount around the large webbing and axle nut on the rear drums of a Kombi but the stud pattern would be fine. You may have to use spacers to clear the webbing and axle nut.
Attached is the only pic I could find. My wheels are all grey though and are AirEvo replicas.
