G'day,
Anyone filled a Splitty steering box with grease rather than gear oil?
Was concidering using Nulon Extreme grease in it as it sticks well as I can't get any 90/140 gear oil at the moment.
Opinions please.
Cheers, Ian.
[ Edited on 17-6-2006 by Desert Bug ]
vwpurplebuggy ·
Grease is not the best lubricant for steering boxes as it is not a self leveling lubricant. Really you need something that has a hypoid additive -.a more liquid fluid As I have done a split windscreen Kombi gearbox before, hwy are you considering putting grease in to the steering boxes as you can easily fix the box by replacing the seal that leaks.
Desert Bug ·
When I pulled the cover off and looked at the mechanism I decided it was best to use oil. Problem was they only had 80w90 Hypoid gear oil and I wanted 90w140, so drove the 20ks back in to town prepared to by a 5 litre they said they had (only needed 250ml) and saw they had 2 rows of 1 lt 80w90 on the shelf and searched through both these and found a 85w140 at the back, so all fixed and working well.
Cheers, Ian.
