Engine Assembly Lubricant
https://forums.aussieveedubbers.com/threads/53703/engine-assembly-lubricant
PurpleT3 ·
What lube do people use when assembling engines, brand, type etc.
Any definite no nos?
Use the same oil as you are going to use in the engine when its running
Cheap, easy, no fuss do spare it either as you assemble check that every component mooves under its own weight or spins freely
I always used this method with no problems
HotRodMatt ·
I've seen one engine come in for line boring. They had prelubed with PERMATEX.
After laughing for half an hour, that shit was everywhere. Had been brushed right into to journals, bearings coated, everything!
They flat towed the car after wondering why it wouldn't turn over...
Don't do that!
71EJVan ·
STP
PurpleT3 ·
All the books refer to using "assembly lubricant" on main, big end, cam bearings etc during assembly. I think they mention lithium grease at one stage.
So you reckon just use normal motor oil rather than grease?
Yep thats what ive used with NO probs
I know there is some fancy compounds out there and if your building a brand new engine then a thin running in oil should be used .... for a few hunderd Klms as it tends to spread easier
Have a look at the fancy stuff ( theres probally 50 differentr brands )
but plent of plain oil and making sure nuthing is tight has done me for ages
Menangler ·
I just use engine oil too, never had a problem, just make sure you spin the engine over on the starter with the plugs out untill the oil light goes out
Chewy ·
Plain oil would be good but you would want to run the engine soon after otherwise the oil may drain from all those vital parts.
If it gonna sit for a while id use moly grease and oil
toplessbug ·
there are heaps of pre assembly lubes out there ,they are all based on moly so make your own ,oil and graphite mix ,slop it on stick it together and away you go ,just make sure you change the oil a couple of times in the first few hours
type3lover ·
I agree with VW54 completely on this.
Assembly lube is not necessary, however some cam and lifter combo's supply a prelube which should be used so you don't void the warranty if there is a problem.
You'd possibly do better to put the extra $$ to more oil changes in the first few hundred K's of the engine's life. There is nothing wrong with changing oil after initial start and run, then 100km, 300km and 1000km. Include filter changes if you have one.
Cheers, T :thumb
Stanley ·
I was told by a wise old engine builder to use a mixture of oil and stp wheh assembling the parts. The stp adds a bit of stickyness to the oil which helps it during the first vital seconds during start up.
