beetle beam adjusters
https://forums.aussieveedubbers.com/threads/53795/beetle-beam-adjusters
pyr0 ·
just a question, i have these adjusters
when welding these onto me beetle beam, and cutting the slot to allow for the adjustment.
here the bit im stuck on do i have the original position of the bolt hole line up in the middle of the adjuster the top of the adjuster or the bottom of the adjuster (the top being the part of the adjuster that would be at the top of the car when the beam is installed)
thanks guys
pyr0 ·
dont worry i answered my own question by looking a little hard, for anyone interested the answer is hear: http://www.thesamba.com/vw/forum/viewtopic.php?t=64301
A question from a non-beamer person
In the picture - the "retainer" that you show (round thing), this aint used??
You just loosen up the one inside the tube???
Barry from memory you have to use the one supplied as the thread in UNF not metric as they make these adjusters for the US market and ODNT like metric threads for some strange reason.
You can use the origional center section ( like i did ) but you have to geta Metric thread set screw
So how do you get it out??
yeah good point
You have to cut a groove where the dimple is taht holding it in place
then side it out the tube
Of course this works best when your also narrowing the beam
yeah it does pose a problem
So it fits "though" those inner and outer bearings??
shaihulud ·
If you fit the adjusters with the bolt in the position of the original bolt, you will be able to adjust up and down and aslo to soften or stiffen the spring rates.
If you set one to adjust up only and the other to adjust down only, you will be able to soften the spring rate for a light fronted buggy and then be able to raise the front end when you go bush with extra loads to carry.
I had my adjusters set to raise the car only as on my buggy I had a soft set of torsion bars.
It all depends upon what you want to do.
You can buy complete front ends from Brazil with adjusters fitted for around $600.
