POINTS AGAIN!
https://forums.aussieveedubbers.com/threads/53950/points-again
butidontunderstand ·
ok im over the points, anything that goes wrong with my car is always points related, what can i do to get rid of them? is it something called electronic ignition or along those lines? where can i buy what i need?
i have a 72 fasty with a 1600 in it
thanks, karina
Yes - you need the following kit.
Either
Magfire (cheapest)
Compufire
Pertronix
Just make sure it fits your dizzy. The stock dizzies need a ring to make things work.
Give
V Force
Classic at Rydalmere
VVDS
etc etc a call
Points "should" be fine though if set up properly
PS
you also need to measure your coil's resistance. needs to be 3 Ω (ohms) to stop burning them up
I wouldnt pay any more than $150.
[ Edited on 4-7-2006 by Bizarre ]
thanks, will do some calling around tommorow
1500S ·
Are they burning at the contacts or just closing up. In this weather, if you don't make sure the cam lobes are covered in grease, the surface rusts and is very abrasive. Doesn't take long to wear the point rubbing block down and presto! no points opening and difficult or unable to start. Is that what's happening? A bit of grease and a check every month is far cheaper than the alternative of electronic for you.
Dh
