NEW 1968 CC ENGINE
https://forums.aussieveedubbers.com/threads/53971/new-1968-cc-engine
RodPenrose ·
I have enough parts to build another engine 74mm x 92mm that includes the following parts
used case , line bored and opened up for 92mm
new std conrods
new 4130 cromoly 74mm counterweighted 8 dowell crank
new 92mm piston and cyl kit
new std heads cut for 92mm
new engle w 110 camshaft
new 26mm oil pump
new aluminium cam gear
new cromoly gland nut
new scat lifters
used flywheel , lightened and 8 dowelled
new main bearings
new conrod bearings
new cam bearings
new german gasket kit
new rear main seal
new std push rod tubes
new aluminium crank pulley
new solid shim rockers
used std pushrods
there is only 1 available at $ 2500 or $3000 assembled . ROD 02-42729920.
BUGBOY ·
Thats a cheap motor!
I don`t know how you do it?
But keep it up:thumb
RodPenrose ·
I still have this engine kit and to sweeten the deal I will throw in a new exaught system of your choice , or a new 1 5/8 merged system , ROD , 0242729920 .
[ Edited on 5/7/2006 by RodPenrose ]
