Factory VW T1 EFI intake manifold and Aftermarker Microtech Digi 1 Fuel only computer and hand programmer.
Condition : Used in good condition
Includes.............
* Plenum / TB Assembly which replaces generator / alternator stand
* tps switch, intake air temp sensor
* Twin port intake runners, injectors, fuel rails and aux air intake bypass valve
* Malpassi rising rate fuel pressure regulator
* Microtech Digi 1 fuel only computer, hand programmer, harness and manual
* Bosch electric fuel pump
This was setup on a 1776 with stock heads and engle 100 cam and ran well (map still resident in computer).
see photo of engine below with setup in place. Installation will require relocation of throttle cable through fan shroud to accomodate different throttle linkage position, and a new Type 3 TLE EFI head temp sensor (available from vintage for about $40.00) as I broke the cable off the one I was using. See additional photos.
$500.00 ONO
Plenum has been bead blasted back to aluminum. more detailed photos available if required.
Thanks,
Wayne.
[ Edited on 5-7-06 by 1964_Notch ]
[ Edited on 7-7-06 by 1964_Notch ]
Euro_67 ·
