window trim/scraper
https://forums.aussieveedubbers.com/threads/540/window-trimscraper
Frenchy ·
this may be a daft one, but i have bought a new window scraper/trim and the dam thing dont seem to fit gurrrrr, the trim clips are to big i have only one of the oringinal clips, as the rest had rusted away hence the new trim.
I replaced one of the new one with these, and it fitted stright in the others are just 2 big any1 else had this problem is it just me being a tit???
Use apply a small amout of grease to the hole in the door that the clip fits into.
also you may have to squeeze the clip with a pair of long nose pliers or long tweezers from the inside of the door to get the clip started.
Che Castro ·
yeah the West Coast Metric ones i got didn't quite fit into the hole, so i had to use pliers, the metal they used for those clip bits broke very easily...
Frenchy ·
yes i found that out i snapped one trying to put the old clip in they seem just a little cheap, will give it a wizz walked away from it due to taking the floor out wil tell ya all when i get it in 😀
Frenchy ·
Right the trim is in i only snapped one of the clips and the quaterlight is back in it looks A OK. Thanks for the advice it worked a treat took mins to do
BUT😠BUT😠
:oTHE WINDOW MECH HAS SEIZED SOLID AFTER 3 WEEKS:o so now i need to spend more on a new mech have taken it off and its shagged knackerd has any one had experiance of the electric window kits that i have seen? need some advice on ths one 😉
