wheel base for early beetle
https://forums.aussieveedubbers.com/threads/54018/wheel-base-for-early-beetle
malcolm ·
wheel base calculated by centre of the drive axle & stub axle ( with the rear spring plate & front suspension arms horizontal with the ground ).
wheelbase measurment early 2400
super beetle ie 1302&1303 2440 and on the late would this be taken from the centre of the pivot point for the lower control arm on the macpherson strut front end .
cheers malcolm.
[ Edited on 16-7-2006 by malcolm ]
malcolm ·
anyone
dangerous ·
This may not be the same point as the stub axle centre line due to caster angle.
malcolm ·
come on anyone else
malcolm ·
bump
Ive just read through my VW handbooks or Instruction manuals that are sold with each car, and the wheelbase is listed as.
The Torsion bar cars up to 1302 & 1303 have 2400mm
The 2 strut models 1302 & 1303 have 2420mm
The late 76 torsion nar and 1300 models also have 2400mm
hope this helps... What is it exactly you need ??
oval TOFU ·
I think he needs to know where to bolt in that L300 front beam!
