Hi All,
I have almost finished mocking up my car before I start cutting holes and start bolting things down and start runing water, oil and fuel lines. What I want to know form some of you is what is the best way to set up for weight in the car. Where is the best place to add and subtract weight to get the car to launch evenly. Do you or dont you want to promote body twist.
I have the 2165 turbo with the turbo at the back passenger side, which under the pass. rear guard I also want to mount a small oil cooler and the exhaust runs from here over the rear axle into a muffler and exits in front of the rear pass tyre. I also have to mount the oil filter etc somewhere, I was thinking under the drivers rear guard but this makes the lines really long. Is this a problem? I also have a air pod/ box under the drivers rear guard.
There is also the oil cooler over the gearbox which I dont really want too close to the muffler and I have it sitting on the drivers side at the moment. I behind the back seat I have a water tank that would weight about 10kgs with water that could go on either side to balance the weight up as with the battery and ECU pumps etc. I have 2 small radiators mounted on the front beam that will hopefully put some weight over the front wheels and last but not least... I weigh 65kgs. Have for the last 10 years and it doesn't look like moving for the moment.
This is in a full interior 54 sedan street car that is going to see some strip work. It is IRS and hoping for around 250hp with a 3.88 and low ratio first.
Thanks for the knowledge,
T54
Turbo54 ·
