Hey guys, I keep blowing a fuse whenever I indicate. I had the indicator switch replaced about a month ago but it has been fine since....until now..
Any ideas if it could be something else?
Jess
bajachris88 ·
next best thing i can think of is have a look at ur indicator wires. IS it only left or only right that blow? Check from the lights onwards, look for a worn out wire that might be earthing on the metal (IE: wire stripped of its insulation and the copper wire touching metal on the body)
make sure ur using the right fuse too for the required amperage the blinkers need.
