Oil light not working HELP PLEASE!!!!! FIXED
https://forums.aussieveedubbers.com/threads/54130/oil-light-not-working-help-please-fixed
Midlife crisis ·
Hi peoples
I have a 73 BAJA Beetle and the oil light is not working I have tried 4 senders no luck so I don't think I is there.I have tried new globes and the glow and I have swapped fitting from the gen light which works with no luck
Now I don't know how the oil light works wether it cuts the earth when the pressure is up or it cuts the power when the pressure is up so please don't laugh at me when you read what I tried to sort this out. LOL
I ran a wire from the oil sender to where the blue wire goes on the light no luck.So I replaced the old wire and got a test light no power at the sender. if you look at the photo's below the first one is a wire that I found which comes from the loom where all the wires for the coil come from just hanging around the coil and I don't know where it goes does anyone know? Then went to the light in the speedo next photo is the light fitting with the test light on the blue wire when it is like this the test light and oil light glow very dim when I put it on the black wire the tester glows as normal so I am lost, can anyone please help me with this as I don't want to drive IGOR to long with out an oil light as he is my only car.
Marc
[ Edited on 10-7-06 by Midlife crisis ]
Midlife crisis ·
Ok I went down after lunch to see if I put a new earth straight to the light if it would work and it did yahoo.
While i was sitting there thinking it hit me in the head like a ton of bricks (AND YES IT DOES HURT WHEN I THINK LOLOL) I remebered that I did not ran a new wire to the sender with the new one in so I did this and it works YAHOO!!!!!!!!!!!!!.
So off now to buy new wire .
Marc
bajachris88 ·
lol, good on ya marc!!!
I have to say... the wiring in the bug has been the biggest bump in the road for me yet :o, But i think i might get it right by this arvo 😀
Hows igor going? 😀
Midlife crisis ·
thanks Chris
The only problem I have now is a really bad headache from thinking to much .LOLOLOL
Marc
marc,
ur mystery wire is most likely part of the computer diagnosis system
my 2 74s had one like that from memory its grey with green trace and hooked to the coil -ve
i used it for my tach wire save running a new one through the quarter panel which is a prick of a job
Joel
