got a 400W amp, 4 way. the HU has RCAs for the front and rear, and also 2 RCAs to power the subs. As its a panel van, Im using 6x9 240W Pioneers in the cab doors.
I then run to the cargo area where Ive got 2x10 subs in a boxed cabinet. I will run splits in the cargo area when I get to that part.
I want also to mount 2 more 6x9s in a rear cab divider. Which Ill box in, these will face out the rear hatch.
The rears right now Ive not installed.
So in the front, when the ignition is off or on, and the HU has kicked the amp, I get a low level hissing off the speakers. Is that normal? or should it be absolutely quiet?
Ive used gold connectors to the amp etc. and RCAs into the amp. Not crap ones. Speaker wire is the thick stuff well insulated.
Whaddayathink?
bajachris88 ·
hmm, u using CD or radio? Does it do it with the engine off? Does it do it always? Does it do it while the music is playing? Even with my computer speakers right now, if i have em turned up full, i can hear em have a little hiss, but when i play music, it can't be heard.
Am thinking on simple terms, whether it be slight interference from electronics in the car, or around the area, or it be bad radio quality or CD quality... either way.... I know there is software to filter out low level hissing and unwanted yukky low level noises (Like a cutoff for pretty low volume noises that allow the real noises (which are projected louder, IE music to come through without the crappiness),
U MIGHT be able to buy an inline attatchment that can filter that out before it reaches the speakers... maybe...
anyways... i'm suppose to be in bed :o
Take a look around though... I get these sorta questions kinda like this at work, but being a noob, this is the best answers i can give...
ColumBUS ·
your hissing is most likely caused by interference by your ignition.
all you need to do is adjust the supressor on your distributor to dampen it.
Vw nutter ·
it could be your power cable and rca's are crossed? this will cause interference, also if you have cheap shit rca's that arent double sheileded, yeah let us know how u go
sinecure ·
Did you run clean, relay switched power directly from the battery for the main bus? Heavy gauge wire with electronic and magnetic noise supressors would be a must for this sort of set up IMHO.
Maybe a freq. range incompatability with HU, amp and speakers?
crewcabconnection ·
No not from the battery...from the fuse box. Im probably being picky. But new to all this stuff. But thats the fun part. I am using decent wire, RCAs and connectors. I don't have any noise supressors. Looks like more work to be done...as if I aint got enough to finish in the next few weeks...thanks for the advice. I suspect that Ill be redoing it ... but Valla is a good place to ask.
