Link Pin replacement
https://forums.aussieveedubbers.com/threads/54248/link-pin-replacement
oldnslo ·
While stripping down front end of 1956 beetle, noticed that out of four link pins three seem okay but one is really worn.
Are these bushes meant to be replaced as a set of four or can one be done at a time?
King pins seem okay too,
blutopless2 ·
is it the pin itself that is worn or the bush??
bushes should probably be replaced as a pair and have them reamed out to match.
I would replace all at the same time as the effort involved to remove n replace will be doubled when the other wear out
make sure you use a bit of wire to remove the old hard grease from the galleries
do both the king and link pins at the same time
oldnslo ·
I think it is the bush that is worn,
Will replace the whole lot
