how do I get rid of these crappy reflectors and put in sealed beams...can it be done? how easy?
got sealed on the splitty and now want them on the bug but..
Rob.
barls ·
i got the semi sealed h4s in my sbug work a treat
robnjo ·
do they just clip in or is there some mod work to do?
barls ·
they screw in on the mounts fitted in the bucket
You'll need a 'frame' out of something else with H4s from the wreckers; Hilux, Pajero etc etc
barls ·
not if you buy the h4 upgrade for the mk1 golf version. micks and others have these in stock
barls wrote:not if you buy the h4 upgrade for the mk1 golf version. micks and others have these in stock
yeah? okay
shaihulud ·
I recently fitted a set of sealed beam assemblies from a Morris Mini Minor. They cost me $25 each with sealed beams from a Mini wrecker. You buy the whole bucket, wires and all. The two top lugs already in the headlight hole in the bug which may need to be bent down, are close to correct. You need to drill one small hole in the bucket to fit the top two screws and then a small piece of 1 inch aluminium angle pop riveted into the frame will give you a screw near the bottom. You need to remove the two big adjusting screws from the VW headlight trims as you need to adjust the headlight with the cover off. I used a self tapping screw top and bottom to fit the trim. A bit of wiring and soldering and hey presto!
Easy as pie. I now have a set of headlights that look good and which show the road well on a dark night in the country.
I think that Morris, Austin, MG headlights across most models from about the 1960s and 70s are all the same.
I believe that you can do the same with Ford and Holden and Valiant headlights from the 60s and 70s.
robnjo ·
Thanks guys, will call mick and see how I go...might take pic of the process🙄
koolkarmakombi ·
Hey Robo,
Install a running earth and power wires and use the oem wiring to shunt a relay.
a-m-a-z-i-n-g light!
kkk
import advantage sold upgrades too
robnjo wrote:Thanks guys, will call mick and see how I go...might take pic of the process🙄
koolkarmakombi wrote:Hey Robo,
kkk
yeah you can buy pre-wired upgrade harnesses to do that - from 4WD or Rally stores etc etc like ARB
im just using semi sealed ones from 76on vws atm with 100/80w bulbs thro a relay and everyone bitches theyre to bright LOL
but for something differnet i'm putting a set of these in with a HID bulb and transformer kit like all the new BMWs, mercs, audis etc have
Joel
I've always had H4s since they came out....
I had sealed beams in a 1302S Super I had in the 70s.
The later 1303S and 76 beetles had the headlamps screwed to the small brackets in the headlamp bowl...
The plastic chrome rim had only the bottom hole...
I usually attach the H4 semi sealed beams to early Ford headlamp buckets then use the two VW long screws to adjust them... I used to use H4 sealed beams... but they seem prone to stone chips... but the lights still work...
The best bulbs to use are H4 Plus 50 headlamp bulbs...
they are 50% brighter on Low beam and 30% brighter on High beam, but still use the same 60/55w...
so the plastic headlamp plug doesn't melt etc because of the high wattage VERY hot bulbs like 80/100w etc...
Narva and Hella both make them....
robnjo ·
I rang mick and he said he had upgrades($98) that are the same a very late bugs.I asked him if they were to crack can any semi-sealed beam go in and he said I'd have to use the beams from a late bug...I havn't see the set-up in the late bugs so will go up check these kits out and work it out, I'm one of those that have to touch things to work them out🤓
barls ·
here they are in chaos rob
i dont have a photo with out the surounds on unfortunately but they are held in by 3 screws
robnjo ·
so barls, If i brake one can I put in any Semi-sealed beam in its place?
