Aussieveedubbers 路 Buying, Selling & Swapping Parts
WTD: rear brake drum(s) - suit oval
https://forums.aussieveedubbers.com/threads/54383/wtd-rear-brake-drums-suit-oval
oval TOFU 路
I'm after one (but will buy a pair if needs be) rear brake drum as indicated in the pic below. It must have the recess around the circumference and be the narrower oval type. Must also be usable and not been machined to a .001" of it's life.. 馃槈
Chris
Melb
ab 路
that loooks like std early drum mate... oval ones are solid without the recess. I should have both, im about to go down to work ill check for you. Whats your number?
oval TOFU 路
perhaps someone has oval backing plates as well then?
oval TOFU 路
got it.. thanks ab. Fits perfectly
