I was looking at the rx7 front disks 5 on 114.3 ford patten with 4 pot calipers .Has any one fitted the full assembly to a link pin stub ( bug )
gull ·
do your own post please
rocknrob ·
I'm looking at RX8 rotors front and rear for my kombi...offset is good for making adapter plate to suit any caliper...and yeah the PCD is close too
klashniv ·
gull wrote:do your own post please
sorry, only posted because I thought it was related. won't happen again, have deleted the offending post
seagull ·
hey no problems , just easy to follow if you have your on post
sea gull
seagull ·
Well I have my RX7 front twin spots & hubs now , going on the new drop link spindles when Humpty gets his shipment in .
seagull ·
Well I got some time today ( only just ) to have a good look at the set up on the front .
I found the outer bearing is the same id as the late RX7 20mm id , the inner will reqire a adapter to bring the shaft size up , but I can use the RX7 bearing & seal .
I will get a plate lazer cut to bolt the 4 spot caliper to .
Cost $200.00
The sud pattern is Ford 5 on 114.3
ratbug ·
Sounds good Neil, if it all works out I wouldnt mind a plate done as well, I have balljoint however are the spindles different?
seagull ·
Hi Andrew , I dont have a ball joint front here to check mate , but thing I will make a few sets of each up any way .The cost to set up the lazer is the most expencive , from there its only a few $ each .I seem to be doing all the bits for cost these days , just gets every one up and going faster .
I truly think this is the best set up there is .
I will hold off for a few days as my drop spindels are coming from the usa ( are they Humpty ? )
The other set up I have is to use all these Subaru WRX & rs calipers & disks I have here .The ford ea is still best for the rear .
I post some photos soon
seagull
seagull ·
I be doing a plate for the super bug as well , Luke needs them .
I can not have him running into the rear of the Dragon , he will be used to the look of the rear of that car 😂
silverbullet ·
i am also following the progress on this one i also have a b/j frontend though. at the moment i just have the bigger type 3 calipers and std discs with pcd 120 x5. but wanting bigger calipers to compensate for the eb falcon rear setup which i agree is great. looking forward to seeing some pics. cheers
malcolm ·
neil are you making the caliper bracket out of steel or alloy .how does the price compare between cnc or lazer .
gull ·
Looking at it , I think it will be 5 or 6mm thick
so steel may be best
Lazer is lower in cost , but punch CNc is now on a par , seagull
malcolm ·
I am looking at using 6061-T651 aluminium plate or 7075-T651 its about $32 per square foot .
get from Airport Metals. email sales@airportmetals.com.au
might even make the floor out of chrome moly sheet or titanium sheet 😂
