F/S 944 alloy arms 86-92(traded for seats &$)
https://forums.aussieveedubbers.com/threads/54465/fs-944-alloy-arms-86-92traded-for-seats
malcolm ·
$650 a pair including shipping in Australia.
these arms normally sell between $800-$1350 each.
seller Malcolm
location Werribee ,Vic
ph all hours 0397421864 or U2U
[ Edited on 20-7-2006 by malcolm ]
[ Edited on 24-7-2006 by malcolm ]
seagull ·
WOW thats cheap
give them a wash they come up a treat !
seagull
malcolm ·
I also have the stub axles & I can get the spring plates
71superbug ·
what is the advantage of using these?
also, what effects both positive and negative would it have on a beetle.
.eg, will i need wider guards at the back if i want to fit 17x7 wheels and these?
Anthony
lots of $ for less weight!
seagull ·
Great way to get the weight out the rear with out mods they bolt up .better axels as well .You could sell the rear brakes anthony .
malcolm ·
there not lighter 400 grams heaver but they don,t twist like the steel arms better bearing support and if you want porsche wheels and brakes easer for engineering.They are wider than the beetle irs rims but with the right wheel offset the track offset want be that bad. track is measured tyre center to tyre center.
ANYTHING TO DO WITH CARS ISN,T CHEAP IN THE LONG RUN.:P
malcolm ·
anyone before they goback to the wreckers for apair of seats or wheels .😀
will give you the same track as steel 944 arms with a wheel offset 52et.got some great info off the nett.
[ Edited on 23-7-2006 by malcolm ]
malcolm ·
gone back to the wreckers .
