12v Twin speed wiper motor
https://forums.aussieveedubbers.com/threads/54675/12v-twin-speed-wiper-motor
Mr Bubble Head ·
This is a working 12v twin speed wiper motor great for making your early bug twin speed $80
Call me 0408 307000 after 4pm
nIck
[ Edited on 25-7-2006 by Mr Bubble Head ]
ab ·
does it come in that box?
karmen ·
would be flat out fitting in the box ...he he
hey bubbles isn't it the switch whichmakes it 2 speed ??
ab ·
no, the motor, the switch passes 12v to the motor. Wiper motor must have the extra terminal for the 2nd speed.
Yes,
its a Bosch wiper motor with two speeds....
and they internally switch into reverse to self park....
very tricky invention that....
Two speeds are better than one....
If the holes in the body line up You can use late model wiper arms that really do wipe the screen....
blutopless2 ·
68AutoBug wrote:Yes,
??? how is this done in the motor?
pretty sure theres just 2 sets of windings in the motor, one bigger for high speed
if u check the switch u'll find that its the same voltage comes off lo and hi
-Joel
blutopless2 ·
thanks... interesting way of obtaining dual speed.
lexm ·
Two speed wiper motors have a third brush. The normal two opposite on the armature
are used for high speed. One of those and the one offset are used for slow speed.
Mr Bubble Head ·
Spot on there is a third motor brush to the armiture at 3 oclock to the other two ie 12 oclock and 6 oclock. Now we've worked out how it works any takers? Ab if its for you I'll make it fit
tdegens ·
Are you coming to valla? If so i will take it.
Cheers Tom
tdegens ·
I'll take it sent u2u
Cheers tom
Mr Bubble Head ·
SOLD
Tom you've got a U2U
nIck
