vw54 wrote:From your note i take it you have a Type 3.... these rubbers are different to Beetle in quality and type of rubber
1. Adjust tthe door gaps and lock settings without the rubber fitted
2. Make yourself a wedge out of a piece of hardwood... bout 200 mm long n tapered say about 50 mm wide.
use this wedge to push the seal all the way home into the groove and you will proberly find there not seating
3. Failing this if its all the way home i suggest you get a new razor blade and cut about 1mm off the back face of the seal
let us know if this works
Thanks VW54, I have good german rubbers for the Type 3 but have been too scared to replace them as the OE still work but look tatty. My queastion actually referred to my newly acquired 73 Dual Cab with new rubbers (good quality). The doors hang out about 5mm.
So same suggestion for these rubbers as well?
