What spark plugs - 1800 kombi
https://forums.aussieveedubbers.com/threads/54741/what-spark-plugs-1800-kombi
GTMac ·
I know where not talking performance engine here but is there a preferred plug that has been given the thumbs up?
Thanks, Andrew
bus914 ·
NGK B5ES for a stock 1800 (equiv bosch W8CC)
GTMac ·
bus914 wrote:NGK B5ES for a stock 1800 (equiv bosch W8CC)
stock 1800 apparently with 1700 heads, does that make any diifference in using the suggested NGK plugs.
bus914 ·
1700 uses the same plugs as 1800.
do you know what plugs were in it before? heat range etc?
how'd you go lowering the fasty?
GTMac ·
Have the originals still in it but not looked at them. Just thought id check on whats good. Fasty is now lowered front end, dead easy when your shown what to do/how to do.................thankyou VWCOOL :thumb
I also recommend NGK. I used Bosch and they were made in India and they failed very quickly.
h ·
bingo n if ya use bosch get ones that are manufactured in germany.. last heaps longer..
made in germany embossed on the plug.
goodluck
Robo ·
You can get German Bosch in blister packs at super cheap.
Rob...
