turbo placement solution...
https://forums.aussieveedubbers.com/threads/54805/turbo-placement-solution
boof2332 ·
In most of the conversions with the ej20t, the turbo hits the firewall or tray area in the splitty where the tank sits. What i did today is simply shorten the "up pipe" about 1 inch. The turbo will drop down and back, making the exhaust bend less severe, heaps more room on the inatke side which is notoriously tight on early wrx and liberty motors, moves turbo away from pressure reg and mainly...helps it fit in.
Cut from the top down, and all the water and oil lines were retained with minor adjustment to their direction. The top turbo bracket was cut, bent and rewelded to help keep the turbo in its new position.
I may bend up a couple to make it easier.
Matt
[ Edited on 29-7-06 by boof2332 ]
seagull ·
at a boy all way thinking
boof2332 ·
adaptor and flywheel fit well... may have another conversion in a couple of weeks to use the second.
Have you got a spare surge pot...I need another.
matt
seagull ·
I am doing 7 pots I have you down for one .
I must say never in my life I have had so many Jobs on the go , all car related as well .
So far thats 10 new subaru Vws in 06 , with 7 of them in Perth .
Pauls KG is going to be one hell of a ride with 94 wrx motor I got for him .
any ( big photos ) Matt ?
cheers seagull
boof2332 ·
I have big photos that I just need to load to the computer. I will ask the owner before I post any pics as he is on here and might like to post them under members rides...
RENNWAGEN ·
Post away Matt.
ElusiveStranger ·
Saw this link on a welding forum.
http://www.inficad.com/~bdhull/engine.html
It's a EJ22 using a Garret T4 turbo for a light aircraft. Might be useful to someone
gull ·
what goes up , will come down ( ! )
I pass flying in that ride
boof2332 ·
Kinda feel the same way..needs a couple of those donks on board to make me feel better.
Matt
