Cam grinding business??
https://forums.aussieveedubbers.com/threads/54926/cam-grinding-business
76camper ·
hey guys,
was going to get my cam reground for my t4 2.0L bus engine. Some1 linked me to a firm in qld who are reputable with this sorta stuff. Does anyone remember the name or website or something of these guyz?
Edward
MickH ·
Is it the mob Stan Pobjoy uses/used?? Give him a bell reverse charge and ask:P
Ivan Tighe Cams
http://www.tighecams.com.au/
dangerous ·
There is a cam grinder in Sydney now that used to be here called "Sure Cam"
Is not cheap, that is for sure, but is the best by far.
(edited to protect the innocent!)
Please check the work of who ever you use, by dialing in every lobe to make sure it is correct.
Sorry if I offended anyones workmanship.
[ Edited on 2-8-2006 by dangerous ]
dangerous ·
That would be an.....U2U Craig.
bus914 ·
76camper, so you've split the case? was the cam gear stuffed?
toplessbug ·
Dave you would be the first person i have heard have a bad word for ivan .could you u2u the details .was it 1 cam you had trouble with
im intriqued
dangerous ·
I have every respect for Ivan himself, and would never personally attack any person on the forum.
Use who ever you like, and check their workmanship by dialing in every lobe.
76camper ·
Hey bus914.
Havent split the case yet. The noise has been getting any worse so i dont think its the cam gear... would have let go by now. Just looking into cams again for a hot up project ;-)
cheers guyz
and craig that was exact guy i was after! cheers
