maximum tyre size for bay window?
https://forums.aussieveedubbers.com/threads/54951/maximum-tyre-size-for-bay-window
megalania ·
Hi guys and gals,
I currently have 225/50 R16 92h rubber on the front of my bus (76) and 225/60 R16 98h on the back and there is super minimal clearance on the back, and going by the sheen on the tyres I guess they are rubbing (currently restoring). What would be the maximum size that I could put on a standard height bay window bus that would not rub the guards? I have attached a pic of my bus. I am thinking of maybe going back to standards. Should I?
VWMA Editor ·
The wheel offset is more likely the problem. If the wheels you have fitted have an offset well outside the standard specs for a Kombi, it won't make any difference which tyres you use. After 1970, standard ET is 41mm. Find the ET stamp on your alloys and compare.
megalania ·
thanks VWMA editor, I will check them asap
megalania ·
ok checked the rims and all I could find was a stamped code of I U 41. Is that a 41mm offset? There were no other stamps on the rims.Is there anywhere in particular I should look?
toplessbug ·
6.photobucket.com/albums/l180/toplessbug_2006/HPIM0852.jpg
these are 215x60x16 on the rear and dont rub :beer:beer:beer
VWMA Editor ·
It should be stamped ET with a number following. My alloy rims have the ET stamped on the outside near the wheel studs.
rocknrob ·
I've got 225/60/16 with ET 35 and have about 10mm clearance to trailing arm and body...perfect!
How do the front wheels fit on the rear? Maybe a slightly lower profile will clear a bit better.
We have 205/55/16 on our bus and they are perfecto
