is it push button, if it is, is all the parts there for it.
steve
davidmaleny ·
sorry steve - bought it with just a slot - no buttons. currently have a maybe on dash as comp. unit.
rear pop outs are gone - still have mountings in mid pillar though.
steering column is there - will list a pick for you on w/end to confirm type you want.
Thanks David
davidmaleny ·
streeing column - have no key - indicator arm not in pic - but have it.
Ren - no front door cards - will check on other two items for you.
ren ·
u2u sent on ignition assembly, gauges and decklid handle trim. Cheers!
DallanMulley ·
Hi is the dash an early wrap round to four piece door panels
1500S ·
What condition is the dash pad?
DH
matara ·
Is the drivers side chrome strip the thick one? Is is straight?
Desert Moose ·
I'm interested in the boot lock and number plate light... I would also like the drives side rear fender but I think shipping would be to much.
davidmaleny ·
ren - rear light housing is not an S, but may have one in store. I'll get the ign./ind. set up together and u2u $, gauges are spoken for,
Dallan - dash is the slot type but not sure on wrap around, arm rests & door cards gone.
1500s - dash pad is a split/cracked as normal. 3 places.
Desert moose - rear light housing $15.00, ( think rens in first but wants an S ) d/s rear fender not bad condition $25.00. ( would be a bit in transport ) can be in bris.
mantara - bottom ones were thick ones, best ones are gone.
Fireball xl5 ·
do you have the reflector for the wrap around rear reflectors?
ruckus ·
if he doesn't have it, fireball xl5, i can help you out, but ask davidmaleny first.
DallanMulley ·
The early dash had pieces that came round onto the top door panel.If I had one could show you.If it is the early one have interest.
Desert Moose ·
davidmaleny wrote:Desert moose - rear light housing $15.00, ( think rens in first but wants an S ) d/s rear fender not bad condition $25.00. ( would be a bit in transport ) can be in bris.
thats cool i'll take it if Ren doesn't, let me know...what about the decklid/ boot lock? and I'll look into the postage on the fender
ren ·
it's all yours, moose. I've got one, but just wanted a 'S' badged version. I'll pass on this one.
davidmaleny ·
fireball x5 fire - have chrome wrap ones but need for resto, sorry - notch in the pic had stubby reflectors not wrap. Ruckus can sort you out.
moose - deck lid handle's yours (see pic cond.) - will send u2u of lock details & $-
ren - still trying to locate ind. ass. for column - will u2u when sorted.
notch65s - posted pics of step trim ? older style is top one I think ?
[ Edited on 6-8-2006 by davidmaleny ]
Notch65s ·
im not sure of the kind that i need. mine is a 65? so i would assume that the older type would be the one? how much would like like for them?
1500S ·
>The early dash had pieces that came round onto the top door panel.If I had one could show you.If it is the early one have interest.<
About the 5th post has a pic of the dash showing that it is off the early (up to 1963 N dash) which is what you want. Suggest anyone getting one of these re-covered that you glue pieces of thin ply onto the ends and be sure to instruct the company NOT to sand the edges to a radius. If they sand them off the fit is crapp. Also best if they clamp the pad to a dash to stop any shrinkage. The last one I had done still haunts me with the fit. Done by the ones around Revesby, Sydney!
DH
1500S ·
>it's all yours, moose. I've got one, but just wanted a 'S' badged version. I'll pass on this one<
Ren, the housing is the same and has 2 holes drilled (5 mm from memory) for the "S" trim cover. You only have to find the S bit.
ren ·
yeah thanks, that's the only bit I want (need!).
1500S ·
How desperate are you!! There must be someone in Vic with one to spare without charging like a wounded bull for it. Let me know if you really do want one and no-one in Vic parts with one for you.
DH
davidmaleny ·
Dallan - it appears to be old style as you are after, first interest guy has not replied ( transport ?)
