What\'s This??
https://forums.aussieveedubbers.com/threads/5499/whats-this
lowrider ·
I've wacked a second hand 1600tp into my Karmann; compression is good (140-150psi)
but it seems to be using excessive oil. Also white smoke from the exhaust when given moderate throttle. Motor is quiet (no untoward noises) and feels strong; do I just live with it??
Andy
Sure do unless you wan tto spend $2000 and recondition it.
Probally sounds like worn Valve guides. My 1500 does the same thing... you could try a heavier grade oil...
Make sure you check the oil level regularly
