Link Pin to Ball joint
https://forums.aussieveedubbers.com/threads/55026/link-pin-to-ball-joint
Der Kafer Trieber ·
how do you go about changing a link pin front end to a ball joint one?
does the beam only need to be modified or does the framehead need to be changed?
jonnyb ·
afraid the whole head needs to be done
Baja Robert ·
Why on earth would you want to do that. Ball joint fronts suck eggs.
66deluxe ·
Baja Robert wrote:Why on earth would you want to do that. Ball joint fronts suck eggs.
I beg to differ.
subibaja ·
definitly disagree with that stupid statement.
a balljiont front with 181 (thing) stubs is the ultimite in ride quality
and yes i do have a linkpin front on my baja but will change soon too much maitnence
terry
Hertz ·
Pull your head in Rob you tosser.
Der Kafer Trieber ·
Link pin is good for a "by the book" resto, but if you want a better ride and some camber ajustability ball joints are the frogs bollocks, so how hard is it to replace the whole head?
urban_myth ·
cut the link pin one off, weld a balljoint one on, make sure you measure it up accurately and it gets welded on square.
It's easier to do a chassis swap
No alignment or strength problems and hey, you need to find another donor chassis anyway...
weld a new bulkhead on itst he easiest way to do the swap
dangerous ·
Who stocks new frame heads and IRS pivots?
Baja Wes ·
pivot boxes;
http://www.customoffroad.com.au/vw/partFull.asp?partid=36
mackaymanx ·
Mick Motors sells the framheads, last time I inquired here was waiting for an order to come in
