Aussieveedubbers 路 Offroad V-Dubs
has anyone reco\'d a fuel tank.......
https://forums.aussieveedubbers.com/threads/55052/has-anyone-recod-a-fuel-tank
tobys mate 路
hey all im just wondering if anyone has recod their fuel tank themself i know u can get the por 15 kit which i was gunna have a stab at but i wanted to know if it works. is there anyplaces in sydney that reco fuel tanks (u know incase i f@#k up 馃檪 ) also what size is a tank out of a 68 1500 beetle as to a L bug one. you all know how it is all the info is apreciated 馃檪...........
5lam 路
How do you mean reco?
repair dints, rust etc? Or just pretty it up a bit?
oval TOFU 路
i used half the POR15 kit for my oval tank. worked great and much cheaper than paying for someone else to do it...
tobys mate 路
yea i mean reco as in recondition like make it new or whatever it is they do right.oval TOFU so the por 15 kit works good is it expensive if u dont mind me askin
oval TOFU 路
abhout $110. that's only for the inside. You really only need half of it, so convince a friend that they need theirs done too so you can split the cost! I'd blast the outside and POR that too (not with the tank sealer obviously)
Kombicol 路
Anyone have any advice on how to deal with a tank which is rusty on the inside?
I finally tracked down an EFI type 3 tank, purchased unseen only to find the careless person I bought it off left it in the rain to fill up with water.
I am thinking of washing it with acid or something similar. Being for EFI, it needs to be cleeeeen.
Volkswagenboy 路
You can also buy the cleaner from Por15 if I remember correctly, not sure though.
-Staggers.
pete wood 路
oval TOFU wrote:i used half the POR15 kit for my oval tank. worked great and much cheaper than paying for someone else to do it...
I did the same, although I remember the kit being $45 dollars not $110. Did a great job. It was recommended to me by a mate who makes custom tanks for bikes. The hardest job is getting the tank dry after rinsing the cleaners out with water. I found a hairdryer best for this.
vw54 路
your better off cutting the rust out and patching with new steel.
Ive done this to a few tanks before and no problems make sure you givet he tank a good wash out with water first.
tobys mate 路
vw54 wrote:your better off cutting the rust out and patching with new steel.
or kabooooooooooooooooooooom 馃檪
