No low beams - Kombi
https://forums.aussieveedubbers.com/threads/55063/no-low-beams-kombi
GTMac ·
Another annoying drama. No low beams. I have parkers and high beams but the high beams wont click in, they only flash when lifting the stalk. I think that is of course because I cant get low beam.
Looked at fuse 3 and 4, sure thats them, OK. Any suggestions what to look at now?
Thanks.
mackaymanx ·
the headlight relay
vwtrev1 ·
I had the same trouble cleaned up fuse contacts and put in new fuses worked fine and still is.
Trevor//
aggri1 ·
I thought mine was doing the same thing, then I realised that I had only pulled the headlight switch out to Park Lights, and then of course the high beams don't stay on. DER! Of course ignition on is required too. Just in case there are others like me out there!🤪
I would therefore suspect the headlight relay too, on the assumption that you haven't done the same no-brain thing I did.
GTMac ·
Ummm yes it was bad earthing with fuses and yes I was no-brainer the 2nd try when I didnt have the ignition key on :o
Funny that but I am slowly learning!
