Pan conversions
https://forums.aussieveedubbers.com/threads/55095/pan-conversions
55low ·
This has probably been covered 100 times but here goes anyway
How difficult is it to swap either a split or oval window beetle to a later model pan and running gear.
I have a bit of mechanical ability but am not in the motor industry as such
I live in the Brisbane area so would anyone local do this sort of thing?
What later year/model pans are the best and/or easiest to swap to and what $$$ would they sell for
Any advice would be greatly appreciated
Here you go
http://forums.aussieveedubbers.com/viewtopic.php?tid=8392
BEST pan is a 68-69 semi auto pan
Comes standard with disc brakes, ball joints and IRS
you have to add a clutch tube.
SOME pans already have it in.
Best part is you are pre ADR rules so further Hi Po mods and hot so difficult.
2nd best is a 1976 pan.
as above PLUS clutch tube.
Down side is post ADR.
Remember - your car will become whatever the pan is.
A 1952 split window would register as a 1976 if put on a 1976 pan
Barry
55low ·
Thanks for the info Barry any idea on how hard to swap everthing over, brackets,any changes etc
55low wrote:Thanks for the info Barry any idea on how hard to swap everthing over, brackets,any changes etc
Um dude, have you read the thread that Barry has so kindly linked for you? That is the only 'major' hassle when doing a body swap. Everything else is a bolt-up
[ Edited on 9-8-2006 by VWCOOL ]
55low ·
Um Dude,
Thanks for the welcome into the VW family
No worries! Plenty on here who have done that conversion
