need help non vw
https://forums.aussieveedubbers.com/threads/55155/need-help-non-vw
barls ·
ok guys im looking for someone who is in to glass blowing or glass working, as i have a cookie jar that needs repairing. whats happened is its a vw bug jar that has been broken and crack in one of the wheels. id like to get this repaired if i can so if someone on here does this or knows someone who does im willing to post it to get it repaired and pay for the repair to be done.
barls
Volkswagenboy ·
I think Karina (butidontunderstand) said one time her sister Monique does that, but I'm pretty sure it's something she's just learning. (I might be wrong).
-Staggers.
butidontunderstand ·
monique makes beads out of glass...i have nnnoooo idea if she could help you or not
maybe if you could post up a photo? that would probably be an awesome help :bounce
Volkswagenboy ·
😀 That's right! Beads!!
-Staggers.
Baja Wes ·
I have the same VW cookie jar, and it's got a broken wheel too :o
Must be a weak spot in the design :P
barls ·
id like to put up a photo but i cant as mines good but the old mans is broken and im trying to get it fixed as a thank you for all the work on chaos
monique__d ·
i do some glass bead work but i dont think i can help you.
it all depends on wot type of glass it is.
do u need a new wheel or the old wheel just stuck together??
i could probably get some names of some people who might be able to help.
sorry i couldnt be of more help.
Mon
barls ·
whats happened is the bottom of the wheel has been shattered so it needs to have more glass added and have the hole filled.
id really apperciate it if you could help monique
monique__d ·
well from wot u have just explained i wouldnt be able to help. the glass working which i do is completely different to wot u will need.
you could try this guy. but it doesnt say on his website whether he does repairs or not. but theres no harm in asking
Peter Minson
http://www.minsonartglass.com/index.html
ill try get some more people for u. ive got some more names but they r somewhere in my room. not exactly sure where.
Mon
bajachris88 ·
i think it might be bad news for ya... you could glue the thing to gether, but refiring (from memory) to reseal the crack and make it non visible won't work.
Was inquiring the same thing multiple times with an art teacher during the subject last yr. You refire the thing to melt it in the kiln right if u want to hide the crack... but... the temperature heating has to be soooo dam slow its not funny (as to not crack the glass/ shatter it any more), but once u hit that temperature, its at a temperature where the rest of the item can melt/distort... and therefore u would need some mould on the entire surface (inside and out) to hold it together...
and nope, u can't just heat one section of the glass where the crack is, as that expands and in turn cracks as the temperature differs from the surrounding glass....
sooo, its either VERY hard or impossible... sorry 🙁
bajachris88 ·
could reseal it with glue, and repaint over it...
Volkswagenboy ·
I have a kiln, we can melt the whole thing into one pretty blob if you want!
-Staggers.
bajachris88 ·
wait.. is the jar ceramic or glass?
Volkswagenboy ·
Mmm... asbestos lined kiln...
-Staggers.
Volkswagenboy ·
bajachris88 wrote:wait.. is the jar ceramic or glass?
Would he be asking if it were ceramic?
-Staggers.
bajachris88 ·
both use a kiln... both are pretty much the same procedure, depends on how badly 'f*&ked' it is.
at least u can refire ceramic though... and hide any cracks with a layer of glaze
barls ·
its glass and i was hoping that like oxy wielding and you could just fill and shape
