Subaru WRX air to air turbo coolers
https://forums.aussieveedubbers.com/threads/55238/subaru-wrx-air-to-air-turbo-coolers
seagull ·
seagull Neil
Perth wa
0407074141
Item .WRX top mount air to air cooler removed from JDM wrx c/w pipes & brackets
$120.00 each
I have two just removed from our front cuts
Did I tell you I am doing a suabru powered bug ?
No oil on my drive way .
got to love quad cam power
seagull
malcolm ·
what motor are you using again:thumb
seagull ·
I got in for the guys here 4 x 1994 to 1996 JDM wrx front cuts for the conversion to Vw .The motors are EJ20T ks from 74000 > 170000ks on the clock .
Mike is fitting the whole motor and gear box mid in the oval .
others Paul ( in KG ) ,Luke,Anthony ( super bugs ) & my self ( 60 bug ) are going out the rear .
Anthony purchased my 94 wrx motor I had
I have a front cut but its staying as is , untill I need it .I have 2 other turbo RS liberty motors in the shed .
I have a RS TT legacy coming over its a front cut 206 KW at the wheels
Hey seagull, can you organise modified/cut down wiring harnesses for the JDM OE computers to suit VW
seagull ·
My man is now off shore & I can no longer get this done .I wish there was some one on here that wanted a few $ to fund there ride in doing them .I have two here now I need doing
Turbo54 ·
Can you post a pic with a 30cm ruler next to them so I can see measurements.
T54
gull ·
I will do late tonight mate , seagull
it will be in MM
