scratch guards on late type 3
https://forums.aussieveedubbers.com/threads/55487/scratch-guards-on-late-type-3
butidontunderstand ·
how do you put scratch guards on my type 3?
they are the ones that go underneath the handles...
i need to take the handles off but I have no idea how to...
thanks, karina :bounce :bounce
ruckus ·
Should be screws on the door on the pillar side when you open it. It might be a bit under the rubber seal.
Yes,
the door handles are the same as Beetles...
thats if its a 1970 on type 3...
the early ones were different...
but , Yes, You lift the rubber off,
and there will be one screw...
You take the screw out and then slide the handle forwards... carefully..
and it will come out...
I have one thick German chromed scratch plate on...
Maybe the aluminium ones fit better... easier..
or the handles are easier to fit back on..
I think I may have to file the other thick german scratch plate to get it on...
Hi Karina,
I just read the Heading where You said its a late model...
so, its the same as the 68> beetles...
I will check it out tommorow hopefully
I was scared to start taking out screws since knowing my luck everything would just break and it would NOT be good
