Any ideas how to make the fuel injection system work? 2l kombi. only goes on one cylinder
[ Edited on 22-8-2006 by tdegens ]
PurpleT3 ·
Any more infor than that? I would suggest that if you are trying to trouble shoot an EFI system, you get a copy of the appropriate manual. There are just too many different things which need to be checked.
MickH ·
More info...new install?? Was it running before etc.. If one injector is working check the wireing for the other injectors.They run batch fire (all injectors fire at the same time)..so you know that your trigger point works....check fuel pressure etc etc...lotsa variables.Just give it to me,i need one👍😵
