Im selling my IBM 21" Monitor as i have run out of room
specs are as follows:
Device Type: Standard display / CRT conventional - desktop Diagonal
Size ( Viewable Size ): 21" (19.8" viewable) 0.24mm Dot Pitch Max Resolution 2048 x 1536.
This model is UltraScan and 100% PC COMPATIBLE and will work with any standard video card (VGA or DVI). IBM P275 is Dual Input Compatible, either video inputs may be selected by a front mounted switch.
________________________________________
Manufacturer: SONY Trinitron FD IBM Part # 6652U3N
Tube Type: CRT 21inch SONY Trinitron FD (Perfect Flat Display)
Dot Pitch: 0.24 mm Aperture Grill Pitch
Viewable Size: 19.8inch
HSCAN / VSCAN: 30 kHz to 130 kHz / 48 Hz to 170 Hz
Refresh Rate - Max/Recommended: 85Hz / 85Hz
Resolution - MAX/Recommended: 2048x1536 / 1600x1200
Type: UltraScan, PnP
Platforms: PC and MAC
Signal Input: 15-pin D-sub (standard VGA plug) and DVI (Digital Video Interface). Dual Video in support.
Power Supply: AC 100 - 260 V
Dimensions: 19.8 in. (W) x 19.8 in. (H) x 20.1 in (D)
Other: Plug and Play. Two video inputs with selection by a front mounted switch.
$200 Pick up only
Located in Sydney.
XXX-1.8T ·
