RodPenrose ·
I now keep in stock a good supply of the new Bugpac and CB performance aluminium engine cases . The bugpac cases are opened for 94mm , clearanced for 86mm , solid behind # 3 cyl , are taped for full flow , are universal mounting , come with 8mm or 10mm inserts and are shuffle pinned on the centre main only , priced @ $ 985 ea . The CB case has the same features but with all mains shuffle pinned and with an extra 9mm deck so you can run a big stroke - long rods - low compression and still use the std mahle piston/cyl kit , priced @ $ 1170 ea thanks ROD , 02-42729920 .
