Gearbox bearing replacement question
https://forums.aussieveedubbers.com/threads/55562/gearbox-bearing-replacement-question
I have a good gearbox that was factory installed with a plastic cage in the larger of the two bearings that are visible with the nose-cone removed. I wish to replace the bearing with a better one. Can anyone tell me - for sure - if the bearing can be pulled (with a puller) off the shaft without disassembling the whole gearbox, after its circlip has been removed? This bearing appears to be a transition/sliding fit into the gearbox case but not sure about its fit onto the shaft
N e 1?
I take it you want to change the bearing because of the plastic cage ???
This isnt a reason to change the bearing if The cage is good dont F.. k with it you need to inspect the bearing race and balls for spalling or flaking to see if it needs repacing
from memory you will have to strip the box to remove
johny rotten ·
Take it to a mechanic Glen
most times that bearing will need replacment
[ Edited on 22-8-2006 by johny rotten ]
yep, plastic cage has collapsed
It's been to a mechanic - he's asking me
[ Edited on 22-8-2006 by VWCOOL ]
mackaymanx ·
I came across this on shoptalkforum may help.
http://www.shoptalkforums.com/viewtopic.php?t=103275
Take it to Henry or Shimo.
How and where? And could I be bothered for an $80 gearbox!!
[ Edited on 23-8-2006 by VWCOOL ]
Depends on what you need the box 4
VWCOOL wrote:How and where? And could I be bothered for an $80 gearbox!!
Steve, what I meant was: How do I find these guiys and where are they
Dave, I want to put it in my 1916 Oval to replace the 4.1 box thats in there now
I might pull it apart for a look-see next week
dangerous ·
If you can find a puller that will fit between the balls to pull on the inner race,
you may be able to get the old one out.
The "fit" on the shaft should be tight, but only firm in the housing.
But fitting a new one will need some support on the other end of the input shaft and some way to get the circlip back on after the concave washer(if it has one).
I do all that in the press with the box half assembled....you could try, but sounds scarey...I'm sure it is possible.
tassupervee ·
Use a blue-tongued spanner, that'll ruin its day.............hehehhe sry M8, juz funnin!
L8tr
E
