I am after a set of carbies for my t4 motor in the splitty. So close to getting it on the road, just need to be able to drive it to the engineer to get it certificated then blue slipped followed by the numberplates. The current fuel injection makes a terrible noise. Iit splutters, bangs and the idle rate goes up and down erratically, followed by spluttering and then stops, so it is coming off tomorrow and thus a set of carbies are needed. I think I will also need a regulator to reduce the fuel pressure to the carbies. If there are a set of carbies within a 100km radius of coffs I will come and get them tomorrow.
cheers tom
barls ·
try my old man his number is 65523190
subimanx ·
Can i have your injection now you've finished with it?? (Mick H)😁
madcamper ·
I'm about to pull the solexes off my 2L (prob this weekend) and am fitting a weber progressive carb. They need a rebuild, and I need the warm air box from the air filter system. But if you are interested u2u me.
tdegens ·
Thanks for the options. Managed to get the bus going reasonably with the injection system. No 3 isn't firing, I am checking the injector tomorrow. Compression is good with new plugs leads and points.
Put some effort into fixing the EFI. It's worth it
butidontunderstand ·
he got it working on friday!!!!!
hes one very happy daddy today I think :P
