2340cc ENGINE KIT
https://forums.aussieveedubbers.com/threads/55630/2340cc-engine-kit
RodPenrose ·
I have put together another full engine kit with the following parts , used as41 case clearanced and opened ,
used scat 88mm pro comp crank , new CB H beam conrods ,new engle cam of your choice , new scat lifters , new HD oil pump with full flow cover , used 92mm piston/cyl kit [approx 10k ] with new rings , lightened flywheel and moly gland nut , new 043 heads w/40mm x 35.5mm stainless valves & dual springs , all bearings supplied , new gasket kit & rear main seal . priced @ $ 3200 with other options available , thanks ROD .
HRD 68B ·
what sort of power would this put out , with a street cam ?, and do the 92mm pistons still have problems with thin cylinders ?
cheers brenton
kroozzn63 ·
A SHIT LOAD..😂
RodPenrose ·
This engine kit is still for sale . I will throw in a new 1 5/8 merged header with stinger to make the deal a little more tempting , ROD , 02-42729920 .
[ Edited on 8/10/2006 by RodPenrose ]
