window winder circlip...what to use?
https://forums.aussieveedubbers.com/threads/55726/window-winder-circlipwhat-to-use
ren ·
what should I use to get the door window winder circlip off? the grooves it's in is so damn skinny, that no pliers I have can get in there. Any clues?
PS it's a '65 notch, and i think the 60's beetles have the same ones...
the early beetles has a small pin driven into the shaft...
I can't remember coming across a circlip...
You can get the circlip pliers that come with 3 or 4 ends,
so You can use them for different sort of circlips
these are approx 4 mm thick..
Have You tried to get a small screwdriver under the middle of the circlip?
I have ground down some screwdriver tips so I can use them for this...
best of Luck
ren ·
I used two BBW tools in the end! well one bbq tool and a kitchen paring knife. got it done ok, thanks autobug.
pod ·
i have an old steel rule with a slot cut out the end for getting window winders with circlips off🙂
silverbullet ·
i also hear that a bent fork works well.
get some thin metal sheet n cut a slot in it to fit the width of the slot in the winder handle and push it out that way
