Hey everyone, i have a set of audi 17inch mags and need to enlarge the hole in the very center of each wheel by about 7mm. How can i do this? Where could i get it done in Sydney?
Thanks,
Alex.
76camper ·
was told can use a dremel?
Plenty of engineering outfits in brooky that will b able to help out.
71EJVan ·
Best way is to get it done on a lathe. 66-68mm I think. Or you could use a holesaw as long as you can locate the pilot drill with some sort of plate bolted to the back of the wheel. Remember some wheel balancing machines rely on the centre hub hole being true to be able to balance correctly. I would not use a dremmel.
