Hello
I was wondering if anyone had a late model beetle collapsable steering column - I have one already but I must have the larger diameter splines because it doesn't fit my after market steering wheel.
Can someone confirm that some of the collapsable columns had the larger splines, and others had the smaller splines?
These are to go into a 1970 beetle. I have the indicator/ignition housing but also am missing the mounting brackets and bolts that hold it onto the body so I need to find that too! In addition I need to find the little spacer/plastic part on the column in the picture below. Plus the circlip pictured as well (not my pictures).
Finally I need a pitman arm for balljoint front end with the steering stops on the arm (only have link pin one with no steering stop bumps).
If you can help that would be great, obviously am happy to purchase the parts.
Alan
Dasdubber ·
