Well the time has come for my much loved fasty to get some much needed tender loving care.
Before I start I would like to stress that this is not going to be some sort of brilliant Dasdubber style resto. I am not a pro or even gigted in the art of car restoration, simply a novice owner semi rolling up my sleaves. I suppose this thread is for the fellow novices (most of us) who can relate to what I am doing and perhaps we can share some information. And who doesn't like a pics of a resto hey.
Ok, I bought the car a few years back and then spent quite a lot to get the engine, wheels, gearbox and electrics right before finally getting her on the road and RW.
When I bought the car I was told it was rust free (I know I know) so the body was of secondary importance to actually getting it roadworthy. Now however I have tired of the ever fading 'mat black' and wish to give the car a full going over before I look to get the car resprayed.
I don't have a lot of money or a lot of room so it won't be a pan off job, however I am pretty much in love with this car so short cuts such as bog and the ignoring of rust just won't be tolerated.
So first up some pics of the car itself, looking a little tired.
[ Edited on 30-8-2006 by fastyman66 ]
fastyman66 ·
pic
fastyman66 ·
this from over 18mths ago
fastyman66 ·
18mths ago
fastyman66 ·
this is her about a month ago.
[ Edited on 29-8-2006 by fastyman66 ]
bus914 ·
nice:thumb:thumb
wacked1 ·
she looks good mate, good luck
fastyman66 ·
with the front bumper removed.
boristherat ·
Thats a pretty thing. Will be even better when the plans come together.
Good luck with it all mate.
fastyman66 ·
lights, etc removed
fastyman66 ·
front left panel removed.
This was a relief as there were thankfully no nasty surprises. In fact she looked very solid.
fastyman66 ·
another
ruckus ·
Just wait 'til you take the rears off. That's where the nasties live!
fastyman66 ·
the front left panel
fastyman66 ·
now apparently there are two trouble spots for type 3 front bumpers,
fastyman66 ·
thankfully the top section of the panel closest to the front windscreen is rust free inside and out.
fastyman66 ·
fastyman66 ·
unfortunately while rust was not obvious in the lower section of the panel, I couldnt help myself and kept investigating... and a little bog was found.
This panel will have to be repaired.
fastyman66 ·
fastyman66 ·
GASBNR ·
good luck,
good to see a fastback being done makes a change from the others.
I've seen a lot worse on the rust front.
I remember seeing this as a body only years ago
OL
fastyman66 ·
Meanwhile I have been gutting the interior with a view to checking out the condition of the floor (pan).
The pan was covered in a black tar like stuff which had actually preserved the pan reasonably well.
You can tell where the tar like stuff is no longer preventing rust however as usually it is difficult to remove from rust free metal, however it lifts and flakes off any of the pan that has rust.
The pan was something I was pretty nervous about, because I knew that the car let water in, which pooled in the floor in certain areas.
However the pan had no holes whatsoever. Surface rust looks nasty, but is easily removed. This period has been a pretty big relief for me.
I also noticed that water had pooled under the back seat on the opposite side of the battery (left side) so was keen to explore this area too, but as the pictures will show, this was absolutely rock solid.
The old black carpet will be replaced (I am thinking grey) and I am looking also to repair the tired and sagging front seats.
crewcabconnection ·
where are all the fasties hiding????come out come out where ever you are....
fastyman66 ·
scraping off the old paint/tar from the floor to reveal the condition of the pan...
fastyman66 ·
fastyman66 ·
fastyman66 ·
fastyman66 ·
The wire brush is tough work, however the grinder makes short work of surface rust.
fastyman66 ·
fastyman66 ·
fastyman66 ·
underneath the tar like stuff the pan seemed to have been painted cream I think, thats where the yellowy sections on the pan are coming from.
fastyman66 ·
This is the section under the back seat on the opposite side of where the battery sits (its behind the front passenger). Water has in the past pooled in this spot and so I was more than a little nervous scraping off the tar in this section.
This is a shot before I had removed the tar/deadener/whatever except for a small section in the middle.
fastyman66 ·
This shot is after the tar has been removed. This section is literally pristine. I had to remove the heater channel connection section for better access.
fastyman66 ·
before painting with rust preventative paint, I am using a rust converter so that the job I do will last. The converter goes on white and apparently then drys darker.
fastyman66 ·
this is after the rust converter has been applied. I will leave it overnight before applying the rust preventative paint.
greenman ·
How much fun is it working on a car in confined unsheltered space. Days and nights like these I wish I had a huge garage with concrete floors and a big long bench with shelves. I suppose it's character building and adds to the fun. Good luck with the job and don't get any wet and dry in the cats bowl.
Midlife crisis ·
Whats the name of the rust converter you are using??
Marc
fastyman66 ·
tell me about it cal68, I dream of a shed, with a work bench, space to open the doors of the car on both sides! and maybe a beer fridge (and a flat screen:P)
But I have what I have and I will make do.
Not sure of the rust converter brand will check this evening and let you know. Nothing special though, straight from Bunnings.
fastyman66 ·
Ok, so this is what the converter looks like the next day.
fastyman66 ·
I will paint that section with rust prohibitive paint later today.
Also did some more mundane work stripping the pan, using a flat head screwdriver believe it or not (boring).
The pan gets better and better as I go towrads the front of the car. There is actually no rust at all around this section, but given I started I may as well finish.
baybuscamperkid ·
nice one, looks like you got a little ripper!
stephenianjames ·
looking good mate..will be sweet when all done (for a fasty):thumb
fastyman66 ·
Thanks Steve, hows the notchy going?
stephenianjames ·
nowhere fast at the moment (like you didn't know that already)
