new generator
https://forums.aussieveedubbers.com/threads/55820/new-generator
camando ·
My generator is shot - only about 1.5v at 2000rpm
I've called around for a replacement (usual VW shops)- quotes from 150 to 200 for 2nd hand.
Then I call Baxters in Knoxfield Vic and they quote me $110 for a new gen and $50 for a new reg.
Has anyone bought from these guys?
They seem reputable because they supply to the truck industry.
BUGBOY ·
Who are they?
are the quoting for a correct vw part?
yes, the pricing seems a bit cheap.... for the generator...
regulator seems a bit pricey
You should be able to pick up a used Generator easily enough....
there must be heaps of them about....
I find most companies not dealing with VW parts, usually,
don't even list parts for Beetles etc any more...
cars over 20 years old usually stop being listed...
no crossover charts etc... part number lists..
Unless this company imports these VW parts and sell them wholesale....
type3lover ·
Is a type 3 generator any use?
If so I have a couple and a new v reg
greedy53 ·
are you testing at the battery or the genny could be the reg thats busted
also you can replace the brushes yourself at home it is the usual colpret
[ Edited on 30-8-2006 by greedy53 ]
You should be able to see the brushes in the generator
see if You can push them down with paddle pop sticks
to see if the reading gets better...
brushes are mostly the cause of generator failure...
see if You can get a quote for brushes
or an overhaul..
or replace the brushes yourself
Or check out the $110 generator
camando ·
Thanks guys,
I've tried all of that, (should be in "help" forum now)
Earthed DF to case, checked D+ to ground.
Paddle pop sticks? I just used fingers...still got them too..
but a good idea, next time.
Bushes are good (heaps left)
Did a continuity test across comutator contacts and got a connection to every one...I think the core has fused.
Sound right?
Looks like I'll get the new one.
http://www.baxters.com.au/HTML/Images/Bosch%20Alternators.pdf
greedy53 ·
yep time to part with the cash i would try the new genny first before i buy the reg pitty your in vic i have a genny you could have
karmen ·
only around $13 to post guys
