Pobjoy Counterweighted T4 Crank for a new project!
https://forums.aussieveedubbers.com/threads/55822/pobjoy-counterweighted-t4-crank-for-a-new-project
I thought I would show a photo of my Pobjoy T4 counterweighted crank for my next project !!
The motor will be around 2.2lt with a short stroke and big bore combo.:P
[ Edited on 29-8-2006 by Craig Torrens ]
malcolm ·
how much did it cost ,if you don,t mind me asking.is that a knife egde counterweight❓
$770, that's crack tested,counterweighted, ground, nitrited and balanced.
[ Edited on 31-8-2006 by Craig Torrens ]
malcolm ·
thanks craig
Gracey ·
Looks good Craig, how long before the projects a goer?
rocknrob ·
Is that a stroker or standard 66mm?
Craig Paton ·
Craig....what are you up to now?
How many projectsdo you have.?
Come on KT tell us wots happening
1964_Notch wrote:What ? not another 1916, but they are the best.
Short stroke and Big Bore is the best :thumb
And yes it's a 66mm stroke crank :kiss
johny rotten ·
is this for raceing KT?
Recreational fun.😀
It's for racing up his driveway :thumb
MickH ·
VWCOOL wrote:It's for racing up his driveway :thumb
BACKWARDS:thumb
66deluxe ·
Not a bad price, i got a 78.4mm counterweighted with type 1 rod journals for $900.00 from the states might look into sending some of my type 4 cranks down to Stan to get the mods done for future engine builds.
amazeer ·
talk to phil matthews about the piston slap noises coming from his engine. I believe he also has 93's
Craig Paton ·
I reckon it could be going into a Splitty and towing his hillclimb car......................?? :o
Comments.... Craig
My mistake, I thought the comment was in reference to a type 4 crank👍
amazeer ·
amazeer wrote:talk to phil matthews about the piston slap noises coming from his engine. I believe he also has 93's
My mistake, I meant to type 103's. :thumb
The size alone won't cause piston slap, what stroke crank is he running?
Big, forged pots will always be somewhat noisy... Just ask Victor and Ben Bray
[ Edited on 1-9-2006 by VWCOOL ]
amazeer ·
Craig Torrens wrote:The size alone won't cause piston slap, what stroke crank is he running?
I dunno. I assume nothing exotic. Probably only the stock 1800 or 2 litre.
I'll just turn the radio up 😉.................although I doubt I will have any problems!
Euro_67 ·
But arent 1916s all you need ?
You are not allowed to run a 1916cc in the over 2lt class in motor sport.
haven't done much on this project....................but here's the P&B's
Nice thick side walls on these puppies !
Is that a 10c peice?
xornge666x ·
looks like a 20c to me, but its been a while since ive seen either!
is this really necessary?!?!
Euro_67 wrote:But arent 1916s all you need ?
colin ·
Do you need any overiders with that crank?
bond ·
cool thread craig - look forward to watching the build. keep the pics comming.
sexy pistons!
nick
BrisDubba ·
Yep will be interesting to see how it goes - but Nick you gotta get out more boy !!
bond wrote:cool thread craig - look forward to watching the build. keep the pics comming.
sexy pistons!
nick
amazeer ·
You need some new pistons, those ones have big holes in the top. I suspect there was a bit of valve float in the old engine. You shouldnt use stock springs over 6750rpm.
Beetspeed ·
amazeer wrote:You need some new pistons, those ones have big holes in the top. I suspect there was a bit of valve float in the old engine. You shouldnt use stock springs over 6750rpm.
I am going to try a 66x103 also, but will put a turbo to it as well 😎
The 66mm cranks are extemely strong by itself; I won't have counterweights welded to it myself, but will use lightenend rods with 22mm pin and light pistons too ;-)
amazeer ·
get a cut off wheel on your angle grinder and cut some grooves around the main bearing journals. You'll get better lubrication above 6 psi.
LOWBUG ·
I was a little confused at the begining of this post, as I thought a T4 crank was from a five cylinder water cooled engine but I understand now.
oooops sorry !
